I ordered the SS oil feed lines when I ordered my BB turbos. I understand that these new turbos will require less oil then the original ones. Should installing these fittings be self explanatory once I am there? I reuse the banjo fitting stamped with a "K" on the RH side and install the pictured banjo fitting on the LH?
https://www.box.com/s/94xns2dbewypt9zb4g36
Thanks for any help as I don't wanna blow a turbo with either oil starvation or excessive. Covering all bases.
Instruction for these SS oil feed lines for BB turbos - Coldfusown12:01:54 03/26/13
